zoran gorski
Artsit: Zoran Gorski a.k,a. kizo
Arscom Studio
house model provided by: Mike Brestel
3DAllusions.com rendering contest
This is my entry made for the contest held at 3DAllusions.Must say Im very happy I took part to the contest.I had the chance to use many of my photogrammetry experiments and develop the workflow more....not to mention how great it feels doing non commissioned work without the client interference
Thanks Russell for all the effort on your side and I hope you manage to run more contests.
The scene is prepared using CINEMA 4D - Maxon and rendered with Corona for Cinema 4D. I made several photogrammetry models including the beach part which was captured with a drone.I used Capturing Reality Arena software to turn photos into textured meshes
Most vegetation is from Laubwerk I only made a few custom plants using 3DQUAKERS Forester plugin.
The grass and some bushes are distributed usnig SurfaceSPREAD.
A "Picturesque" and remote cabin living is the theme of this contest.Using the provided butterfly cabin model (made by Mike Brestel http://mikebrestel.com/arch/)
I used a lot of photogrammetry made models including the beach rock formation. some is drone photogrammetry.
After various "sketches" I picked this POV as my final entry as I felt it works the best.I decided to go for a vertical frame composition and have the roof against the sky to make it stand out.The centered frontal POV helps with that too. In contrast I tried to make the surrounding less cultivated and a bit rough but picturesque with many details. The pine tree trunks, the stone garden walls, the olive tree as well as the stump are my photogrammetry models.
The ground texture and stone on the house are custom made textures while I used a combination of textures on the wood elements of the house.The right hand wood facade is from the original file.
The trees and bushes are all Laubewerk models while the grass is made with Forester but distributed using Surfacespread.The Blackbird is a free model and very common in my area.
I used Corona for c4d 6.3 version.The scene is lit with corona sun + sky and I used light mixing to tune. The background with clouds is a photo that I added in post and I haven't done any postwork other than sharpening some parts in PS.
