Víctor M Feliz
Víctor M. Feliz (Motiva)
I think that with the new rules it could fit here!
Description (Content, Project execution):
MOTIVA COLIMO
is a post-production tool designed with the main objective of changing scenes after the rendering process in real time without losing quality.
CHANGE LIGHTS, COLORS Y TEXTURES
Using prerendered images as base you can change colors and textures and his influence on the scene including raytraced reflections/refractions and GI effect. To understand better see the Videos&DEMO section. In recent versions may even change the focus distance to change the depth of field (blur depending on distance) or generate stereoscopic images.
REALCAMERA+
Add real photographic film filters to improve your images, and vignetting or chromatic aberration to increase the realism. Use bleach bypass to create new looks or even in the latest versions you can change the focus to change the depth of field (blur depending on distance) or generate stereoscopic images without render two times the scene.
RENDER ENGINE INDEPENDENT
It does not handle 3D data so the meshes are no longer needed. You can share your project without sending your meshes! Colimo only needs a few render passes of our shader in Modo 501 or Mental Ray, or any render coming from Thea Render.
ACELERATED BY GPU
All processes run on the CPU in 32-bit buffers, taking as fixed size the viewer itself but allowing saving in the size of the original images.
Distinctiveness (what makes this project stand out?):
It brings the full quality of an offline renderer, whatever you use like Vray, Maxwell, MentalRay or of course Thea, to an interactive application that can also generate interactive webs for your customers.
