Martin James
Martin James - Porter James Media
Here we have a typical example of the type of visualization images we produce at Porter James Media. As with every image we create, we will always try to focus on the most eye catching or dynamic
part of any image, and as I’m sure you will agree, having the pool table tight to the front of the image shows that this room is something special, also picking up on the obvious that this is a games room.
As with a lot of architectural visualisation projects we undertake, this room was designed and specified from floor to ceiling by an interior designer. This means that everything has to be modelled and textured specifically for the image in question. This does increase cost as it directly increases time but can create a more refined image. However if we do not receive specifications for fitting out a property we have a 3D model library of fixtures and fittings that will suit any interior style.
