Oliver Wiegmann
Germany
Additional Software used: Nuke | zBrush | Rizom UV | Forest Pack | Rail Clone | Sini Software | Pix Plant | Photoshop | Topaz Gigapixel AI
"Homecoming."
One challenge in this project was the limited availability of graphics memory, as the entire project was rendered exclusively in RTX mode with a large number of object instances and high-poly objects on the graphics card, in order to keep the render time as low as possible. Another goal was to create the desired lighting atmosphere using only a sun light source in combination with an HDRI sphere.
In this non-commercial project, I gained many valuable insights that I have directly integrated into my daily workflows.
The use of AI was limited exclusively to image scaling.
Rendering Engine
V-Ray
Host Platform
Autodesk 3ds Max
AI usage
For post-production
