Lorenzo Mazzi
Lorenzo Mazzi
The first question that comes to mind even before traveling is "What will we eat today?"
Well this settlement tells about this.
The architecture is created in circular modules, dug into the ground so as to keep the crops fresh and to let only the necessary light filter through.
The houses are located inside the central body, above which the photovoltaic panels are positioned.
Each district is autonomous having its own cultivation of food inside.
Not too far from each district, the power station is located, from there the energy is drawn and water is stored.
The connection between them is underground through tunnels, for the bravest you can even move on the surface.
Can you spot how many people are there?
Rendering Engine
Cycles
Video Card
NVIDIA Quadro
