Reza Kaboudmehri
Anahita Shariatmadari
Rendering Engine
Keyshot, V-Ray
Sources of Inspiration and References
this used minimal shapes and lines to design this piece of furniture, and tried to show the feeling of movement and dynamism by using triangular shapes in accordance with the origami philosophy. In this way, the furniture remains beautiful even without any symmetry in the form. From different views, the lines and angles of the forms are convergent and parallel, and that creates a pyramidal shape. According to the principles of fengshui, the energy accumulated at the tip of the pyramid can visually reduce stress and anxiety and increase calmness in the audience.
“Arrow” is a luxury tow-seat sofa designed for sitting and lounging.Its pyramidal shape not only makes it beautiful and comfortable,but also can create an optical illusion and make the environment dynamic and exciting.Our priority was to avoid using wood in the furniture.
The metal structure is covered with injected foam.The foundations are molded using press method.Special places have been smartly designed on the sofa’s arm for putting a glass and a bottle.Our challenge in designing the sofa dynamism by creating geometric pyramid shapes in accordance with the origami peaceful and confusing feeling; I reached such a form by use of arrows element.
Video Card
NVIDIA GeForce
