Valentin Dobre
Valentin Dobre
Outer Space Visualisation
My personal project for the summer. The idea was to come up with a concept for a fisherman's cabin.
The design is composed of twin volumes placed near each other with a slight rotation between them. The geometry process started with basic tent-like triangular prisms and after experimenting with different ridge inclinations and corner chamfers it resulted in some interesting entrance facades with overhangs that work as canopies. It also made possible the placement of a skylight window above the secondary entrance which acts both as a lantern bringing natural light inside at an angle and also as a lighthouse that can be visible from a distance when interior lights are on. The two triangular volumes are connected by a short rectangular walkway with glazing on both sides for increased natural light.
The concept for the cabin was designed using Archicad and 3D Max.
The mountains were designed in Gaea. Two separate meshes were created and then imported in the scene in 3D Max mixed with a manually generated terrain using simple modelling tools.
All vegetation is from Maxtree plus some Megascans assets and scattered using Forest Pack. Sky is HDRI from PGskies.
The images were created with Corona renderer.
